need help with factory speakers
What do I need to do to get the 4 ohm speakers to work in my camaro...these are the ones in the back seat..if you are sitting in the back seat they are sholder high..not back in the cargo area...how do I make them work...or will they work in my car??
The Firebird DVC subs have a four-pin connector. When looking at the connector with the locking tab up, the two top wires are the positives and the two lower wires are the negatives. For the two-pin connector on the car's wiring harness, the wire colors may be blue or green depending on year, model and which side of the car but there will always be one dark colored wire and one light colored wire (they may have white or black stripes as well). The dark colored wire is always the positive and the light colored wire is always the negative. So connecting Firebird subs in a Camaro is simply a matter of wiring the two upper connections on the speaker to the dark colored wire in the harness and the two lower speaker connections to the light colored wire.
Now, before anyone gets their shorts in a knot - that general rule applies only to the woofers/subwoofers in an F-body Monsoon system. It is not necessarily true for other cars or systems and it doesn't apply to the tweeters (which are powered by the head unit rather than the amplifier).
