2000 Z28 Instrument cluster replacement
Old Mar 25, 2020 | 06:42 AM
Seb.a's Avatar
Default 2000 Z28 Instrument cluster replacement
Hi everyone !
Since i bought my car, the instrument panel doesn't light up when i turn te lights on.
Yesterday I removed it to check the light bulbs and saw it has some burnt part inside.
I read somewhere the panel replacement is not a simple plug and play. It seems that there is some program to change so the instrument panel works with the car.
Could you confirm program has to be modified or not ?
If it does, could you tell me where to do it ? I'm in France so there is no Chevy dealer nearby.
Thx
Old Apr 7, 2020 | 09:25 AM
Seb.a's Avatar
Nobody knows if the instrument panel is a direct replacement ?
Old Apr 7, 2020 | 02:09 PM
WhiteBird00's Avatar
Ungrounded Moderator
There is nothing in the instrument cluster of a '99+ Camaro ('98 is different) that prevents its installation in another vehicle other than the odometer will be wrong. That could lead to legal issues unless you get a shop to fix the odometer. In some states, you can get the swap certified with the different mileage and they will install a label noting the change. I don't know how the laws in France work.
Old Apr 7, 2020 | 02:17 PM
Spamfritter's Avatar
Technically speaking, it should swap in with no modification. They are all pretty much the same. That said, WhiteBird00 is correct. There are legal issues with doing so. However, I am totally unfamiliar with the laws in your country on that.
Old Apr 7, 2020 | 10:12 PM
Seb.a's Avatar
Great !
Thanks alot for answers.
It is forbiden to modify the milage if a car in France as well but i thimk i'll able to find someone who can modify it and set the correct one. The most important is that i can replace the instrument cluster and drive the car to a shop that can do the milage modification.
The correct milage is reported on the technical inspection every two years so i can't reduce it anyway.
Old Apr 14, 2020 | 07:48 PM
LS1121's Avatar
if you take the cluster apart you can actually swap out the LED and your mileage will be correct. I did mine. It is very tedious and you need to be very careful.
Old Apr 15, 2020 | 03:31 AM
Seb.a's Avatar
Thanks for your answer. It's good to know.
I'm looking for a used instrument panel. I'll then try to swap out the LED.
Old May 9, 2020 | 02:27 AM
LT4vert's Avatar
Any 99-02 cluster is interchangeable and will work fine, but it will have airbag light on if it isn't programmed to the car. The airbag module is vin tied to the cluster. If you had a Vauxhall dealer, and possibly Opel, where you live, I would have to assume they would be able to program the cluster. The Monaro/Commodore of the Fbody era used alot of shared GM electrical architectures.
Old May 12, 2020 | 02:54 PM
Seb.a's Avatar
I'll check that possiblity.
Thanks
Old May 21, 2020 | 03:00 PM
HappySalesman's Avatar
This is incorrect. I swapped a cluster out of a T/A into my Z28 and don't have an airbag light on. I don't see how/where there would be any VIN encoding into the cluster, considering the whole damn thing is just analog. If you had a GTO or something with an information center sure, but our cars are pretty basic when it comes to electronics.
