heeeeeeeeeeelp!
Old Jul 19, 2004 | 12:48 AM
01SSCloneZ28's Avatar
Question heeeeeeeeeeelp!
ok...i gotta lil problem here n i need sum help sortin it out.....at night when my lights turn on...a lotta the times my headlights and my overhead lights and all the lights in the car start flickering....anyone know what i can do to get rid of this???
Old Jul 20, 2004 | 02:59 AM
LS1Baron's Avatar
Get a higher rated alternator. It's a common prblem.
Old Jul 20, 2004 | 03:00 AM
LS1Baron's Avatar
Or, you could just leave it tached at 3000-3500 RPM... which is a lot more fun!
Old Jul 20, 2004 | 03:08 AM
Snootch's Avatar
Do you have a big system? What is placing a large load on your electrical system? If you have none of the above, check your fusebox, maybe something is loose...? When it does "flicker" what is your battery voltage?
Old Jul 20, 2004 | 03:14 AM
LS1Baron's Avatar
I, and a few of my friends, had this problem. Voltage remains fine, but the lights still flicker. A higher rated alt clears it up. I'm currently running a 200A alt in my car, and it hasn't done the flicker since.
Old Jul 20, 2004 | 10:46 AM
VIP1's Avatar
Copy & Paste Moderator
If you have a stock stereo and haven't added any taxing electrical components, then a higher output alternator is not needed. Its probably a bad electrical connection somewhere.
Old Jul 20, 2004 | 03:56 PM
Wildman's Avatar
I am with VIP1 on this one. No need to replace the Alt, unless of course it is the source of your problem.
Is it actually flickering, or does it dim for a second? It might just be your A.I.R. Pump that you are seeing.
Old Jul 21, 2004 | 12:02 AM
i have the stock monsoon stereo system in my car.....my voltage jumps from mid to 3/4..........all my interior light(dash, stereo, etc.) flash along with my headlights
Old Jul 21, 2004 | 12:31 PM
VIP1's Avatar
You say mid to 3/4, what #s on the gauge? I consider "halfway" to be 13v, So it's peaking above 13.8v? like 15 or higher? You should experiencing 13-13.8v at idle, no more than 14v, and no lower than 11-11.5v. If you are seeing "surges" of 15v+ It is something wrong with the voltage regulator within your alternator. I would also check the 12v connection from the battery to the underhood fusebox at the fusebox. The connection has a red cap on it. See if it gets really hot, possibly you have a bad connection there. good luck with it.
I'll second that.
On another note....
How come the time stamp of your post is after mine (by several hours) but I posted after you? Look at my quote and you'll see what I mean.
Old Jul 21, 2004 | 07:58 PM
Snootch's Avatar
Old Jul 22, 2004 | 01:48 AM
Wildman's Avatar
I'll second that.
On another note....
That happened to one of my posts on the Western Forum section. My post had a time stamp of 5:52 pm... almost a full 4hrs into the future, so my post kept bumping down and down. Now that the time stamp is caught up, it is where it would normally be. I think the board had a hickup.
Sorry this went off topic.
Paul
Old Jul 22, 2004 | 09:59 AM
Snootch's Avatar
Wierd....
Old Jul 27, 2004 | 12:17 AM
Default solution
found out my alternator was taking a ****.....thank u Ford ESP Warranty! got a new alternator for $100...now i just gotta get my torque arm in that just got here today..and get my tranny leak fixed...
