Battery ground
Old Jun 22, 2021 | 09:00 PM
chevybayboy's Avatar
Default Battery ground
So a bolt that hold the battery ground to the chassis broke off can I bolt it to the head? What does it control?
Old Jun 22, 2021 | 09:14 PM
B52bombardier1's Avatar
The heads should each have their own ground, IMHO. The chassis needs its own ground as does the body, core support and the transmission, if electronic. Good grounds don't control anything per se but support proper operation of everything electronic. Quite simply, you can't have too many grounds and my best / fattest grounds are all braided half inch bare cables soldered into low impedance connections.
I'd find a different good chassis location for that ground or try to remove the broken bolt for a replacement ground.
Rick
Old Jun 22, 2021 | 09:20 PM
Rick
thank you
