Solder
Old Jun 22, 2021 | 03:35 PM
Mustang Hat'r 2's Avatar
Default Solder
I work in the electronics field I've solder all kinds of surface mount though hole blah blah. Why wont any of the wire in these cars take solder? I had to fix speaker wire, wires for the back up lights, hatch etc. not one wire would take solder for crap. Is there some type of super flux I need to solder them? I have a Weller soldering iron, not some radio shack crap LOL,
Still no luck
Old Jun 22, 2021 | 03:54 PM
wretched73's Avatar
I've never had the issues you have had.
I also know that crimps are preferred for cars. The thought being the vibrations will cause the solder connection to break.
Old Jun 22, 2021 | 04:39 PM
pdxmotorhead's Avatar
The wire in cars is insulated with Soy-oil based plastic, it doesn't take solder worth a hoot, and the residue seems to go away about the same time the wire melts.. LOL
Also,, properly done crimps, are the proper way to wire vehicles, soldering wires to connectors will fatigue the wire right at the end of the solder and eventually they break off, UNLESS you back up the solder job with a heavy shrink wrap, or you only solder on the tip of. the wire to the connector and don't let solder bleed down the wire through the crimp. .
None of the aircraft I was around in the military used solder in the wiring harnesses either.. Just NICE crimped connectors properly done with the right crimping tools..
Old Jun 22, 2021 | 04:47 PM
shakenfake's Avatar
Because the car is so old the wires have a bit of corrosion on them. Ask me how I know, 1999 Silverado has the same issue. It is a pain to get the stuff off.
Old Jun 22, 2021 | 08:41 PM
SAPPER's Avatar
I'm a tech at a GM dealer and been building on cars about 40 years now. The best thing I've used yet it the low temp solder connectors. The import companies use them but GM doesn't. They still use the good old heat shrink crimp connectors. So I supply my own low temp deals, that way I don't have any comebacks. Haven't failed me yet.
Old Jun 23, 2021 | 07:52 AM
Amazon Amazon
Are these okay or do you have specific brand you can recommend?
Thanks
Old Jun 24, 2021 | 07:19 AM
SAPPER's Avatar
Thanks
Yes. I get mine from where ever I find them cheapest. They all work. I use a butane torch or a good heat gun. Heat the ends first to hold wires in place then move to center to solder.
Old Jun 24, 2021 | 10:43 AM
VIP1's Avatar
Copy & Paste Moderator
Here is a review of that style of low-temp solder connector.
Old Jun 25, 2021 | 05:34 AM
Thank you.
