Rpm gauge
Has the harness or engine been modified?
Sounds like something is mechanically wrong or the PCM is trying to keep the car from imploding.
You didn't mention re-tuning for the 5.3 since the swap. LS1 and 5.3 tunes are different and won't run right without being tuned. Any tuner worth talking to can and should data log to help diagnose the issue before and after loading a base 5.3 tune. Tuning software can see a LOT of information at the same time to see what's not producing an expected signal. I should add experience with these cars is a huge benefit.
And you have to validate the engine you installed is wired in a fashion compatible with what you took out..
No offense intended, but its a Tachometer that reads RPM, you can use a ultra-gauge which is a small glass dash that can give a lot of info ,, < 90 bucks.
and it can be mounted in the car to give more info than the stock gages.. Must have the OBD2 connector under the dash to use it. It also shows and clears codes.
