Power antenna to fixed antenna swap?
Ungrounded Moderator
That depends... is it an antenna and bracket from an f-body? If so then you will not need any other parts. F-bodies used an oddball antenna cable that has a male mini-motorola plug on both ends. That was true of both the power and manual antennas so swapping them between f-body models is very easy. Swapping from other vehicles - even other GM vehicles - can be problematic.
