using multiple 4 gauge instead of 1/0 gauge?
0 AWG cable is about 105,000 circular mils.
00 AWG cable is about 140,000 circular mils.
Three 4 AWG cables is right in between 0 and 00 AWG size cable, and exceeds ampacity of 0 AWG cable (related to the amount of copper in the bundle). However, it may be a bit difficult to make the physical crimp to bring those cables together. You're good to go if you can get that figured out.
Places like CE Auto Electric have presses than can make these 3 cable crimps and you can have them do it before sending you the cables. Although they use PVC insulation on their battery cables which is not desirable. Best to use SGX insulation because it's tougher to rubbing / abrasion. Most the safety in battery cables is careful cable routing, clipping, and choosing tough insulation material. SGX is pretty stiff, doesn't turn corners very easy, but it's the right stuff from a safety perspective.
Firewall along door sill
Along sail panel
Power and sail speaker wires
Along sail panel
https://www.youtube.com/watch?v=jy1I1Cbci_o
