BCM question
Old May 23, 2023 | 06:56 AM
sunfighter's Avatar
Default BCM question
Don't know much about this stuff. Will the BCM I pictured work in my 2000 z28 Camaro? This module and key came out of a 2001 Camaro, but, it's a v6. I've searched a lot of threads but can't seem to find the answer.
Thank you.
Old May 23, 2023 | 02:25 PM
PHTCBRA's Avatar
Yes, the part number of the BCM 09353691 is the only thing that matters. As long as the key is paired, it should work no problem, V6/V8 are all interchangeable as I just did this about a week ago (2002 V6 Firebird Parts Car) into a 2001 Camaro SS car.
I now have a working Key, BCM and Remote, which I also was able to Program a 2nd new remote.
FYI, I've seen a few people have issues with starting the car after a BCM replacement. I'm not sure why, but it seems that the Gauges Fuse (10A) blows when installing a BCM. Mine did this and wouldn't allow a start signal to the starter. Replaced Fuse and all was good, along with allowed me the ability to program a new remote.
Amazon Amazon
This is the one I used.
Also, you may want to open up the BCM box and see what condition the 5 relay solider joints are in. Would be a good idea to drop some solider on them if possible.
https://ls1tech.com/how-tos/a/camaro...-module-419320
HTH
