Slower two prong LED flasher?
Web electric products who makes the sequential kit said their unit does not control the flash speed, it's run by the flasher. Any suggestions would be greatly appreciated. I attached a couple of links so you can see.
https://photos.app.goo.gl/C6GTi2xmGaNkSQqA7
https://photos.app.goo.gl/Wg4J44KrMueYoqGA6
The broader thread is an extensive one on sequential flashers.
I tried a few cheap ones from Amazon, I was told this one works well but not for me.
https://easyperformance.com/products...flasher-module
Your vid says private
My buddy can sodder the diode but I would buy the keep it clean if it defiantly will work. How is it different?
Last edited by wssix99; Oct 6, 2023 at 08:16 AM. Reason: email removed to prevent spamming and scamming
The Amazon flasher will definitely work. The one I made is identical in operation. The difference is that, since mine is homemade, I had a little more control in the speed. The potentiometer is a variable resistor and I put that inline with a static resistor. The two in combination gave me the resistance I wanted for the flash speed I wanted. I'm not sure what the speed the Keep It Clean unit will give you, but if you don't like it, you would have to make your own as I did. Changing the static resistor out for different values puts the unit in different brackets of speed.
I changed the video on YouTube. You should be able to see it now. Thanks for letting me know. No one ever told me there was an issue with it! If you can't play it, please let me know.
