Voltage drop to pumps issue
Tested the wiring this morning and I am getting a 1.1V drop from the alternator stud to the pump bulkhead on both the red and blue power wires. I have tested EVERY location along the routing path. Voltages are as follows: 14.4V @ alternator, 14.3V @ fuse ( on the side going to the back of the car ), 13.5V at the power going into the relay, 13.3V at the power going into the 7-way connector, and 13.3V at the bulkhead connector. Dropping 1.1V over a relatively short length of wire is troublesome.
The wiring is routed along the same path as my fuel lines, along the driver's side of the car. Exits from the top of the tank on the passenger side, drops down to where the relays are mounted and the ground wire is attached to the body. Goes across above the axle, turns and follows the fuel lines up front, then diverges at the firewall and goes behind the cylinder head and intake and travels over the top of the intake next to the fuel rail. Hotwires are then attached to the output on the alternator, and ground for the pumps is attached to a stud that grounds to the block.
I cannot figure out what is causing this drop in voltage, there's a 0.8V drop in the length of wire running from the fuses to the relays in the rear. That's excessive for 10AWG wiring. Does anyone have any ideas of how to fix this? I'm attaching a screenshot of a datalog so the fuel issue can be seen:
i would start with replacing the crimped ends and see if that helps. if not, the whole run of wire needs to be replaced.
this is assuming you already checked all connections are properly seated/secured
Not saying that IS your problem, but Real, genuine Belden copper 10 Gauge will carry 30 amps and not heat up.
Also, make sure your crimp terminals are tin plated COPPER and not nickle plated STEEL. The STEEL ring terminals are sometimes used in high voltage industrial wiring, because they can handle heat better, but NOT EVER useful for 12 volt DC wiring, where the conductivity of COPPER is essential.
Also: crimp, solder and heat shrink all connections, if you are able.
To do an actual "voltage drop" test, you are checking two points on the same circuit and the circuit has to be loaded(current flowing) This can be done on the positive or negative side of a circuit.
All a DMM does is show the differental in voltage.
When you put the postive lead on the positive battery post and the negative lead on negative battery post and the meter shows 14.7volts, what it actually means is there is 14.7volts at the postive side and 0 volts on the negative. That's checking voltage.
When doing a voltage drop test the lower the number the better, the higher the number is bad.
A high number indicates that between those points, there is excessive resistance that is "dropping" the voltage. This can be from undersized wiring that can't flow enough current, broken wire strands inside the wire, corrosion or bad crimp on a terminal. That's why using ohms to check if a circuit is good is absolutely pointless because there is no current flowing in the circuit. The only thing a ohm test is good for is to test for an open circuit.
Examples of a voltage drop on your fuel pump circuit would be, remember the fuel pump has to be running
One lead on the big terminal on the alternator and one lead on the fuse, .02
One lead on the fuse and one lead on the 30 terminal of the relay, .02
One lead on the 87 terminal of the relay one lead on the power wire on the fuel pump, 2 volts.
This would indicate there's a problem in the wiring between the 87 terminal of the relay and the fuel pump.
Another thing you can do is test the entire circuit. What I mean is leave one probe on the alternator, start at the fuel pump and back track.
This will show the voltage drop of the entire circuit starting out and as you work back towards the power source, you will find where the problem is.
I hope some of this made sense. I always find it hard to explain what a voltage drop test actually is.
Needless to say, I emailed them and asked for their recommendation on the second one..
