Window Problems Help
Old Jul 30, 2004 | 11:16 AM
wes96z's Avatar
Angry Window Problems Help
has anybody had a problem w/there windows rolling up and down?
my windows will roll down but when i try to roll them up they go very slow and then stop i have to turn the car off then turn it back on and they will roll up a little more and i have to repeat this process until there up fully
Old Jul 30, 2004 | 05:12 PM
ninety6's Avatar
your window motor needs to be replaced. You can get a replacement motor for like $50 at autozone (i think).
you can get one here for $40:
http://www.1aauto.com/1A/WindowMotors/Chevrolet/Camaro
i bought from them before, received quickly, and worked fine -- its an OE style (NEW)
to replace:
1. remove door panel
2. drill 3 holes in inside door fiberglass (where rivets are in old motor) (these are covered by the the door panel)
3. drill through rivets to disconnect old motor
4. mount new motor with included screw/bolts..
i am pretty sure you do this with the window UP!
i once found a step by step with pictures somewhere, but couldn't find it just now for you, sorry! :-)
Old Jul 30, 2004 | 05:15 PM
ninety6's Avatar
http://shbox.com/page/windowmotor.html
https://ls1tech.com/forums/general-maintenance-repairs/192795-window-motor-replacement.html
