will the monsoon changer hook up to any monsoon deck?
Ungrounded Moderator
The 01 Camaro with Monsoon should already have the changer harness installed so you can just mount it and plug it in. You will find the harness taped to the left rear (hatch area) speaker harness. Just reach under the plastic trim to the speaker and you should find it. The changer will work with any Monsoon head unit newer than mid-1999. Before that it would only work with the cassette head unit.
Originally Posted by mushroom281
well I just have the the tape deck. where is the best place to buy a used changer?
Sean
