no display in clock area - delco
I hate to buy a new unit cause of the display!
I am dealing w/ the same problem right now. I searched all over online for a replacement bulb and all i found was this...http://www.corvetteradios.com/Page7.html. If you take the unit apart you'll see a bulb that looks exactly like the first bulb on that webpage (titled Pontiac Radios Display Bulb). But its like $18 shipped for the bulb!! I ended up going to a place called Specmo in Flint, Michigan and they repair radios and they sold me the bulb for cheaper. I'm not sure how many other locations they have outside of MI but, if you're in Michigan, I would suggest looking there or talking w/ them. you can go to www.specmo.com and e-mail them too. or if you want to call the place where i got mine, the number is 810.744.2940 - maybe they'll just send you one.
On the same note though...does anyone know how to take this bulb out? It says on the website mentioned above that you just turn it w/ a flathead screwdriver but the two metal leads are soldered onto the board on my unit. Unless I have someone help me w/ two soldering irons, I can't get this bulb out! Can anyone help?
On the same note though...does anyone know how to take this bulb out? It says on the website mentioned above that you just turn it w/ a flathead screwdriver but the two metal leads are soldered onto the board on my unit. Unless I have someone help me w/ two soldering irons, I can't get this bulb out! Can anyone help?[/QUOTE]
I just called and he said it just twists out with a screwdriver - no solder. They sent me one for $16. Maybe call them yourself...
I'll post up after I get it and finish the install. I've seen this question unanswered a dozen times in here
i will try to put mine in when i install my wired FM modulator for my Delphi XM SKYFi!
It will be a while before I get the bulb and do this so you might want to finish up yours.
Thanks again and good luck!
so i joyfully ran out to my car to hook it back up and it didn't work. I'm not sure what the problem could be. I might have scratched the PCB w/ some pliers i was using to try and get the old bulb out. could I have put it in backwards?
I will try some stuff tomorrow. I know the display works still b/c i can still see the numbers, it just doesn't light up. :o( this sux.....i'll post more info later...
i ended up getting a blob of solder on but it still didn't fix it. i will try to post pics later but i don't know what the problem could be. it's really ticking me off though >:o(
anybody have any ideas?
I only pulled the radio out far enough to see the back of it and the only wire I disconnected was the antenna wire -- it was re-inserted before I tried to use the radio again. Everything else works fine, even illumination of the rest of the radio when headlights are on....... just no display. I also tried jiggling all of the wires and tapping the display and the top of the radio... not even a flicker.
Any ideas???????
Any ideas???????
It would seem they would do a buld rather than entire unit replacement if that is the issue...
I bought the bulb from specmo link above and my mechanic installed it per instructions from corvetteradio link above. Just pulled the radio out a bit, pried the face plate off with the circuit panel. The old bulb was crusty and he took care removing it. The bulb comes with the little insert around it. He put the insert then the bulb, turned on the radio - display!!
Put it back in all under 15 mnutes and $20
