Reverse Lights Not working ?
Old Dec 27, 2004 | 02:24 PM
2000Z28M6's Avatar
Default Reverse Lights Not working ?
Does anyone have any comments. The obvious first. I replaced both bulbs. I checked the sockets for power and its ok. I engaged it on reverse and power comes to the sockets and disengage reverse and power goes out, so why are the bulbs not working? What am I missing here? First the drivers side went out so I replaced it with a single filament bulb not actually the same one that goes but it worked and now they are both gone. The bulbs in there now are the replacement ones.
Old Dec 27, 2004 | 08:54 PM
WhiteBird00's Avatar
Ungrounded Moderator
If you have power and new bulbs but they still don't work then the next thing to check is the ground. Use a multimeter to make sure that the sockets have a good ground connection.
Old Dec 27, 2004 | 11:29 PM
2000Z28M6's Avatar
I was tellin my buddy bout it and I kinda snapped and thought about that too.. thanx for chipping in gonna check out tomorrow. Thanks
Old Dec 30, 2004 | 12:45 PM
InfiniteReality's Avatar
I've pulled my taillights off and re-installed them before. I put the reverse lights turn signal light hole and tested them. Took me several minutes to figure out why my inside signals weren't working.
Old Dec 30, 2004 | 06:18 PM
2000Z28M6's Avatar
well i found out I have a voltage of .1 Volts In the sockets? WTF? anyone have any ideas? Grounds workin fine.
Old Dec 30, 2004 | 07:59 PM
If you're not getting full power to the socket, the first thing to check is the backup light switch. They have been known to go on manual transmission cars and cause all kinds of wierd symptoms (how often have you seen a car's backup lights on all the time or flash with every shift?)
Old Dec 31, 2004 | 09:18 AM
2000Z28M6's Avatar
so the backup light switch is located where????? Sorry for the bone head question.
Old Dec 31, 2004 | 02:00 PM
The switch is in the middle of the housing on the right side of the transmission. The brown wire should have power when the ignition is in the RUN position. The light green wire should have power when the ignition is in the RUN position and the transmission is in reverse.
Old Feb 10, 2005 | 09:41 PM
yekta's Avatar
guys I have the same problem, is this common?
Old Apr 10, 2005 | 04:03 PM
Blacknite84's Avatar
I just got to looking at mine, because mine havent worked since I owned the car, and mine has been ripped in two, the wires. Im trying to find out hwere they are routed so I can replace it, but thats just something u might check.
Old Apr 10, 2005 | 05:08 PM
Frontman's Avatar
I have the same problem, for the second time. It's the stupid activator switch.
Old Apr 11, 2005 | 11:17 AM
yekta's Avatar
yeah it's the switch problem, I got it fixed in the service
Old Apr 11, 2005 | 11:31 AM
2000Z28M6's Avatar
wheres the activator switch ?????
Old Apr 13, 2005 | 09:40 PM
2000Z28M6's Avatar
anyone know I really get it fixed.....
Old Apr 14, 2005 | 07:29 AM
The switch location is in my post (#8) above.
