factory alarm is driving me crazy help
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Just recently my alarm (factory) has been acting up I activate it when gettin off somewhere and within a couple of minutes sometimes even longer the alarm just goes off by itself. The car is not touched no one with a loud system drives by or someone with a huge cam open headers drives by to set it off. And I've observed it before to see If it does go off by itself and it does
and when I deactivate it it honks twice like if I'm activating it I dont know if maybe a sensor is dead or what but I'm tired of it even when I just lock the car manually it will go off.
My question to you guys, where can I disconnect the alarm. In the rear passenger just by the spare tire there is a black small box should I just disconnect that?
Any info will help Thanks,
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
i had the same problem, i just turned down the sensitivity (on that black box) and everything worked out just fine.
