Did you solder, twist, crimp, etc. your after market HU wires to the factory harness?
I am installing a new HU in my car. What is the easiest and safest way to connect the new HU wires to the factory harness. In the past I would use crimp connectors. What do the stereo install people do?
Ls1tech Bad Ass
it generally doesnt make that big of a difference; i always prefer soldering, but crimp caps are a quick fix that hold 99% of the time... just dont use wire nuts
Originally Posted by SSactionLs1
get a Gm wire harness so you dont alter your stock wires..then just use crimp caps or butt connectors..
![](http://www.partsexpress.com/images/265-606m.jpg)
2. Get some red "crimp connectors" or "butt connectors" from radio shack or Home Depot, then connect the harness that came with the radio to the harness mentioned in #1
3. Plug car harmess into your harness, then into your radio.
4.(P.S. your'e also going to need a GM antenna adapter:
![](http://www.partsexpress.com/images/265-580m.jpg)
to convert the mini GM antenna plug to standard size)
Good luck!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
i always try to solder/heatshrink everything i can. but with the deck as long as you use QUALITY crimp connectors you should be fine. make sure to use the right size as well, and give the connectors a little tug after crimping them to make sure they are tight.
always best to solder/heatshrink tho. even if only for peice of mind.
i always just twist the wires together, fold it parallel to the wire, and wrap it real good with electrical tape. once all the wires are done i tape them all together for added strength. sometimes i will sodlier the wires too if its in a place where it might come undone or the wires arent holding together on a quick tug test. i never trust crimp connectors, had way too many problems with them.
