Good one for u guys
Old Mar 4, 2005 | 12:14 PM
Vertigo's Avatar
Question Good one for u guys
I have this problem. When its cold i'll turn on my rear defroster and after a few momments it will automatically turn off. No problem...BUT here is where things get sketchy. I will try and turn the defroster back on to finish up defrosting the window but it won't turn on! AND....my power seats no longer work!!!! I wait for about 5min and everything is fine again???? Whats going on? THX guys!
Old Mar 4, 2005 | 04:42 PM
Gregg 00SS's Avatar
I think it is a fuse, do a search. I have the same problem. Defroster only works for a few minutes, and then goes off. Can't restart the defroster unless I turn the vehicle off. I've never bothered looking into it too much seeing I don't drive my car when it's nasty out, and she stays in the garage when home.
Old Mar 4, 2005 | 05:18 PM
02blackSS's Avatar
Replace your 30 amp relay (big silver box) in your interior fuse block with a standard 30 amp fuse. For some reason those relays are crap and they don't work, had the same problem, did above and works just fine now!
Old Mar 4, 2005 | 09:40 PM
Midnight F-117A's Avatar
02blackSS is correct. The circuit breaker is a auto-reset type, it opens when it detects overcurrent and closes when it cools down inside, almost like a thermal switch.
The ones in there are crap, I don't think they are really rated at that capacity, otherwise it wouldn't have done it.
Replace it with a regular 30 amp fuse and it will stay on for 10 mins, shuts off to cool down for 2 mins or whatever the timer is set at and can be turned on for another 10 min.
Just don't set the power seat to it's stops with the rear defroster on otherwise it will blow the 30 amp fuse you put in. Hence that's why a auto-resetting type circuit breaker was put in there in the first place.
Old Mar 5, 2005 | 12:44 AM
tuffluck's Avatar
i think the defroster cuts off before it gets the rear window too hot, and if you try to turn it back on, it won't come on. i was told this anyway. never tried to mess with my power seat afterward though...besides, that's kind of an odd coincidence that you needed to adjust your seat immediately following using the defroster, don't you think?
Old Mar 5, 2005 | 11:55 AM
In the GM LS1 F-body manual, it says it has a 10 min timer. If it shuts off under 10 mins, it's not the defroster overheating. It's the cirucit breaker opening and resetting itself after a few mins.
Say you turn the defroster on, you see the light go off shortly afterwards, like under 10 min. Go and adjust your power seat, it won't work.
Old Mar 15, 2005 | 01:26 PM
Vertigo's Avatar
Ummm ya It was real cold outside when we....I mean I got out of the back seat and moved up front to go home...
Old Mar 16, 2005 | 02:40 AM
2MuchRiceMakesMeSick's Avatar
This was covered in several threads. Try doing a search next time.
The resolution was to replace the factory fuse with a bigger 30 amp fuse. While I dont recommend this at all, some people have been ok so far to date.
Old Mar 16, 2005 | 02:17 PM
Vertigo's Avatar
sry rice! you said you graduated recently? I'm about to grad from Virginia Tech! What ru doing now that your out of school?
Old Mar 16, 2005 | 02:24 PM
Shuck's Avatar
I had the same problem and just put in a 30 amp fuse also.
Old Mar 17, 2005 | 08:42 AM
Vertigo's Avatar
and it worked?
Old Mar 18, 2005 | 04:14 AM
Originally Posted by Vertigo
and it worked?
Im a corperate ***** now
The money was just too good not to
at your !passanger seat mod
While exceeding the manufactures current rating for a particular circuit is not recommended, a few guys are doing it sucessfully and they have not reported any problems to this date. Just be aware that you exceeded the amperage suggested by engineers and you could risk burning components such as your seat and defroster and any wires connecting them. You also have the risk of a small fire. Of course this is the worse case scenario, just know that your increasing your chances by doing this.
Old Mar 18, 2005 | 01:48 PM
Vertigo's Avatar
Yeah i was going to say ..nice *** Z06 right out of school you must be doing well! Congrads! Can't wait till/if i get there.
Old Mar 19, 2005 | 02:52 AM
Been like this for 3 years.
Old Mar 20, 2005 | 04:34 AM
Laugh it up. Ive seen cars catch on fire cause of stuff like this.
Old Mar 20, 2005 | 05:04 PM
BrandonSS's Avatar
What do you suggest then if you disagree with the fues solution?
