Audiobahn True Digital Amps???
This is in correct. Run a distorted signal through a sub for an extended period of time and see what happens.....burnt voice coil
There are alot of reasons a sub would distort. Not only the input but the amp itself or the sub.
Clipping is when a component such as a transistor reaches its max potential and cannot produce any more. The top of the sine wave flattens which is known as clipping. Whats left over is turned into heat which is the number one cause of electrical components
That must be a typo cause I have never seen a 30,000 watt audio amplifier
Its not that hard....
1. First turn your gain on the amp ALL THE WAY down.
2. Turn your head unit a little less then 3/4 of the way up.
3. With the car running, Turn the gain up untill you hear distortion.
4. Back off a little and your gains are set.
Mono block (typically class D amplifiers) do have more distortion but most people cannot hear the unclean sound when below 100hz
in my opinion and experience they are awsome. don't know how any of there other model amp preform.
here is a link when all the stuff was hooked up to my Grand Cherokee.
http://www.sounddomain.com/id/sexyvic1
now i began to transfer it all to my 01 tahoe.
Also No Typo ..we Run 30,000 Watts To A Single 18 Inch Speaker..have You Ever Heard Of Linkable Amps And Quad Coil Sub Woofers.... 3750 Watts X 2 + 4 Voice Coils === 30,000 Watts...also That Is The Loudest Car In The World Period.
also do u guys burn out a sub everytime u burp it or does the sub stay alive for a few comps? i would love to see pics. thanks buddy.
The loudest car in the world is a single 18" sub....
Im not even going to comment on that one.....SPL is sound pressure level.
The way you get pressure in your car is by moving a peice of paper (a cone) which moves the air creating pressure. It does not matter if you put a million watts into a sub it will still have the same EXACT SPL as one using half the watts moving the same EXACT amount.
The only advantage to running a high wattage amp is durablity and control at higher xmax's or as you know it...linear excursions.
I THINK WE KNOW HOW SPEAKER WORK.PRETTY AMAZING THAT YOU CAN DO THAT # WITH ONLY 1 SPEAKER.I THINK THAT CONFIRMS WE KNOW WATTZUP.ALSO WE BUILD OUR OWN CUSTOM WOOFER TO OUR OWN SPECS.
