Where To Mount Component Crossovers?
Old Mar 15, 2005 | 02:16 PM
sexyvic1's Avatar
Originally Posted by InfiniteReality
Thanks!
Yep it's a divided enclosure. I thought about putting them under there and as they would fit, I want to keep that space open for my sub amp which I'll have at some point. Not sure on the size of it, but I'd like to keep it there and not have to move the cross overs.. I'd love to find a place to show them all off, since they're kinda cool looking (and I can see if I'm clipping the amp if the bulbs are glowing)... But I'll end up having to hide them some where..
i wouldn't keep the sub amp down there. it needs to breath, it will get to hot under the box.
i think the amps look real nice where they are, maybe u can just get some masonite and build around the amps so they look flush and it hides the wiring.
and if they fit mount the crossover flush in the same masonite right btwn the subs and where your rca cables go into the amps
Old Mar 15, 2005 | 02:19 PM
sexyvic1's Avatar
BADHOOPTY :
what r those red and black things in btwn the speaker wires in the pics. are those quick disconnects / or just crimps ? i haven't seen that b 4. thanks.
Old Mar 15, 2005 | 03:27 PM
InfiniteReality's Avatar
I've thought about how to get it to breathe, other than a fan which still will only blow hot air across it. Choices... I've always heard of people usings masonite, but not exactly sure what it is. I need to make a trip to Lowe's and check it out.
I'm hoping that when I get around to making a cover for the 2 amps I have now, I'll have only 2 windows to see the amps so the wires will be covered. Maybe I can somehow mount the sub amp on top? Might be something to think about before I start on the cover cause I'll have to have to redo it if I don't do it now..
Thanks for the input!
Old Mar 15, 2005 | 06:00 PM
sexyvic1's Avatar
masonite is a thin dark brown colored board. it is like 1/8" - 1/4" do u know what a peg boards is? it is the board with holes throughout it where people hang on their walls to hang tools from. if u know what i am talking about....masonite is the same board but with no holes. one side is rough and the other is smooth.
Old Mar 15, 2005 | 07:03 PM
2MuchRiceMakesMeSick's Avatar
That looks pretty good. Alot of time when into fiberglassing everything.
Hes right about the amp. That thing will get hot. I would look for a new place to mount it. The life of your amp depends on it
