Replace the alternator or no no ?
Old Mar 10, 2005 | 08:26 PM
2001FireBird's Avatar
Default Replace the alternator or no no ?
Alright, so last weekend I was running up north to Sac for test & tune on saturday. The same morning I was turned up the boost on my amp to make my 10' pound a little harder. Anyhow, while in the middle of the freeway my car shuts off and the batt gauge just drops to a dead 8. I end up calling a tow truck and the guy advises me that a car does not just "die" out of no where. Says to me that the alternator is the most common cuase of this and tells me I should replace it. First I ask him to jump the batt just to see what's up, in a matter of seconds the car dies yet again. I'm pretty convinced he was right. However, Today I jump the car with my trusty sentra and the car idles for a good 10 minutes. I then test the system again, but lowered the boost to the way it was before I uped it, the batt gauge dropped to a flat 13. This means I need a new alter w/ more amps? or what? Any help guys? Thanks
Old Mar 10, 2005 | 08:54 PM
Christos's Avatar
um, boost?
Old Mar 10, 2005 | 09:35 PM
Not like boost like forced induction... the amp i got came with a small remote that gives a "bassboost" . Sorry for the confusion./
Old Mar 11, 2005 | 04:34 PM
sexyvic1's Avatar
what model amplifier is it and how many amps is it drawing? also do u have any other accessories running?
Old Mar 12, 2005 | 06:43 PM
Richiec77's Avatar
Remote Gain. It's the same thing as turning it upon the amp.
So yestarday, when the car was hot and you were drawing more from the Alt, the car shut off. Today while it's cool, you do the same thing + turn down the remote gain and the car seems fine.
Sounds like a Heat induced condition. Probably the rectifier is on it's way out in the Alt. Look to probably be replacing it in the future and check around for a bigger unit if you plan on keeping a larger stereo.
sexyvic1 asked the question that I waould also need answered.
Old Mar 13, 2005 | 02:08 AM
2MuchRiceMakesMeSick's Avatar
I would check the wire that goes from the alt to the batt. Make sure it is not loose.
