Power antenna wire question.
Deck remote to 2 Diamond amps (D5600.2 and D51200.1)
TCS 12v switched to Power antenna (convertable switch I made) then to the antenna motor. If I need to use relays, which ones should I get. Never have messed with relays much.
Thanks.
Let me ask you this. Your antenna wire, does it lose power when your listening to a cd
Heres what the bottom of the relay looks like
Heres the diagram
86 = switched on wire (such as ignition wire)
85 = ground
30 = to your amps
87 = 12v (from your battery)
Youll need one 12v relay you can pick up at radio shack (usually 30amps) and some spades
Antenna would stay up even when playing a cd. No antenna wire from the HU.
Here:
http://www.fbodyaudio.com/articlevie...4thgenfaq.tech
Here is the writeup for the power antenna switch. It's not that hard. If you already have tcs you need to buy the convertable plate and top switch.
http://members.shaw.ca/ritc1/Antenna.html
Heres the diagram
85 = ground
30 = to your amps
Also, I'm only using the remote from the H/U for 2 amps in which neither pulls many amps on the remote in. Would a relay still be needed.
The other ignition sources I spliced I only did for switched power.
I'm using the TCS switched power for the antenna switch which is totally independent from the H/U. I'll probably use a relay here since I'm guessing the antenna motor pulls quite a bit of amps.
The only other place I spliced into is for the PAC steering wheel controls which seems to pull almost no amps at all. Doubt I need a relay here. Correct?
In your case 87 would go to the cd player
