*quick* Adding factory keyless entry into a non-keyless 1998 Z28?
Can it be done? I need to know asap so I can get to work on it!
Thanks!
Thanks!
Thanks!
Part# 9353691 = 'Module, Body Cont' with keyless entry
Part# 9353681 = BCM without keyless entry
Aha... https://ls1tech.com/forums/showpost....43&postcount=2 says "there are 2 bcm's one for keyless, one without."
https://ls1tech.com/forums/showpost....73&postcount=6 says the same, and confirms that it's simple to swap them out.
And here's details of the keyfob programming sequence: https://ls1tech.com/forums/showpost....85&postcount=2
List of everything else the BCM controls: https://ls1tech.com/forums/showpost....1&postcount=14
LOCK CONTROL, REMOTE ENTRY(KEYLESS ENTRY SYSTEM)
That "should" mean that I only need a key FOB, right?
Give the programming sequence a try. Last edited by ACW; Apr 26, 2005 at 09:15 AM.
Thank you for your help and patience!
Glad to help, post how it turns out!
