monsoon and window problems
Old Apr 18, 2005 | 01:16 PM
tschmidt098's Avatar
Default monsoon and window problems
sometimes all of a sudden my cd player turns off and the antenna goes down, when that happens my power windows also stop working. what could this be, thanks for all the help
Old Apr 18, 2005 | 03:29 PM
Daley's Avatar
You've got a bad connection SOMEWHERE. Unfortunately, the wire that these two components share is before the fuse-block, so some digging will probably be necessary. It's either that or some issue near or related to the BCM. I'm assuming this happens most often when you hit a bump?
Old Apr 19, 2005 | 01:17 PM
it doesnt even happen everytime it hits a bump, just out of the blue, where would i look for this connection problem
Old Apr 20, 2005 | 01:39 PM
t t t
Old Apr 21, 2005 | 07:37 AM
2MuchRiceMakesMeSick's Avatar
Need to check for that loose wire like daley said.
Ive even seen where the blade on the fuse itself was loose.
Old Apr 21, 2005 | 01:37 PM
alrite thanks for the help
Old Apr 22, 2005 | 02:07 PM
would this wire also cause my windows not to go down
Old Apr 24, 2005 | 03:46 AM
Kirby's Avatar
Only if it had anything to do with your accessories fuse.
Old Apr 25, 2005 | 05:18 PM
thanks ill try to find the problem this weekend
