AMP has contant beep
Old Jun 3, 2005 | 10:25 PM
fox_forma's Avatar
I appreciate it, thanx again. One of my buddies had a similiar problem way back. I forget what kinda amp it was but he sold his sytem to someone and they hooked it up wrong and he said it was a similiar case to what i am going through, but he just junked the amp instead of getting it fixed or anything. I have never hooked a system up wrong before as far as i know but if thats the case what could go on it. Any speciffic area to focus on? I didnt use this amp for a while because I have 2 others but i want to use this one now because both my other amps are either to small or have to much power and this is just right. It wasnt used for a long time and it worked before this whole episode so its confusing me. Once again thanks man
Old Jun 22, 2005 | 05:45 PM
fox_forma's Avatar
Still havent got this taken care of, what can having the wrong size gauge wire do to this situation. I am only running an 8 gauge power/ground at the moment so could this be causing the amp to do this and possibly heat up to fast? I switching over to 4g next week hopefully but just wanted some input if this could be the culprit.
