monsoon questions
Old May 15, 2005 | 06:39 PM
ls2 bait's Avatar
Default monsoon questions
i just bought a 99 ss with the monsoon system and the front speakers are blown so i need to replace those and i want to put my pioneer dvd 6500 in but would like to reatin the monsoon amp and the rear speakers--does anyone have any suggestions??
thanx
Old May 15, 2005 | 06:50 PM
2MuchRiceMakesMeSick's Avatar
This has been talked about over and over again. Try using the search
Old May 15, 2005 | 09:31 PM
ls2 bait's Avatar
i did use the search and saw all 800 threads--i kind of hoped someone could just give me 1 reply to answer my questions instead of spending 3 hrs reading every other question about the monsoon system.
Old May 15, 2005 | 11:09 PM
Daley's Avatar
I think what he's trying to get at is use the search, but narrow it down a little. Instead of just serching for 'Monsoon' for example, try being more specific. We actually like answering peoples' questions, otherwise we wouldn't be here to help. But it does get old answering the same questions over an over. The info's definately there - just do a little digging and I'm sure you'll find it.
Old May 17, 2005 | 01:52 PM
Roarin_8's Avatar
Yeah read the most common FAQs sticky and it has the link to replace the stock speakers.
Old May 17, 2005 | 05:24 PM
ls2 bait's Avatar
put pioneer speakers in today and they sound okay--nothing special but im not going for sound quality here--i searched for 2 hrs last night can someone please give me 2 simple answers..
1: if i put my cd player in will i lose the rear speakers
2: does anyone make an interface to let the stock chnager work with an aftermarket (pioneer) cd player-it has aux controls.
Old May 17, 2005 | 09:09 PM
VIP1's Avatar
Copy & Paste Moderator
Here is the sticky at the top of this section:
https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
There is plenty of info there on replacing the speakers for better sound.
1. Depends on how you wired the front speakers. If you just connected the new aftermarket speakers to the existing wires and made no other changes, then no you won't lose the rear speakers.
2. Not that I know of
Other Info (real quick rundown a search would get you more detailed info):
* Its easy to install an aftermarket headunit and retain the use of the stock amp and speakers. You just need a wiring harness adapter and an adapter to fit a 1 DIN aftermarket headunit in place of the factory 1.5 DIN headunit. -- Read the sticky for more info.
* The new aftermarket speakers are most-likely 4-ohm and the stock speakers are 2-ohm, therefore the new aftermarket speakers will sound lower/quieter than the stock speakers although they will produce cleaner sound. -- Read the sticky for more info.
* You can retain the use of the steering wheel controls with a PAC SWI-X -- Read the sticky for more info or search.
* The stock Monsoon amp is in the spare tire well -- Read the sticky for more info.
This is all from memory.
The sticky has plenty of info on this, check it out.
Old May 17, 2005 | 09:17 PM
ls2 bait's Avatar
thank you i appreciatte your help.
Old May 17, 2005 | 10:19 PM
VIP1's Avatar
You're welcome.
