Easiest place to find continuous 12V source?
Where is the most accessible 12V continous power source inside my 99 trans am. I need this source to hook up my wideband sensor and an LED. I would like to be able to do this without running a wire through the firewall from the battery if possible. I suppose I will need to fuse any source I find so I already bought a fuse with .5 A fuses.
Any help would be greatly appreciated and pics of where to find the wire would be greatly appreciated!
Thanks
Im not the best when it comes to electrical stuff. Whats a DOV? Also, whats the easiest way to get to the red wire?
What size fuse do I need to run?
Would it be better to just pull a line straight from the battery?
Thanks Again
And 2muchrice is right on how to tap it.
if you dont have tools, the best way is to spread the wire (a blade of some sort, but dont touch any part of the tool on metal
), and poke a hole through the wire so you can now run the new wire into that line, and twist/tape it..it wont go anywhere...
