aftermarket stereo/alternator questions
I have an aftermarket system in my truck, and since putting it in, the volt meter after about 5 minutes, will dip down to about 11.5-12.5. It's used to be around 14-14.5. I also have a 1 farad cap wired into the system. Do I need a higher amperage alternator? What one should I use? This is in an 05 Sierra extended cab z71. I believe that it is a 145 amp alternator in there now. Should I also upgrade the battery?
Thank you!!
Thank you!!
I assume your reffing to the stock voltmeter? The meter will fluctuate some as electrial componets are turned on and off, and the stock meter isnt 100% accurate. what is the current draw from your amp? 11-13 is normal operating range of voltage
The meter will fluctuate when no other components other than the stereo on.
I listen to heavy metal music with alot of continuous double bass drums. Maybe it's putting just a bit too much strain on the alt trying to keep up with the current draw demand?
