Best Subs For Ta
https://ls1tech.com/forums/wiring-stereo-electronics/339802-my-new-system-pics-inside.html
Here is a suggestion.....check out the various orgs such as DBDRAG, and MECA and see what those boyz are runnin' with and the numbers they are hitting. KEEP IN MIND these guys are competitors, and squeeze every bit of juice they can find and optimize their rides for maximum output. (enclosure design, sound deadening, etc.)
Also to be considered are the limitations of the hatch area......so if you want dual 12's it is tough using ONLY the existing well space. Suggest (2) 10's, however, you can go w/stealthbox or millhouse boxes also w/single sub.
Again, you have many, many options available to you depending on preference.
