splicing into accessory outlet??
I was thinking of splicing into the 12volt accessory outlet inside the car to run a radar detector so I can hide the wires. I wanted to wire it up in series so that I can still use the outlet for other things, like my phone charger. If I run two devices on the outlet at the same time will I blow a fuse? How much power is safe to draw through that circuit? Any input would be appreciated!
Thanks!!!
I would use the ignition space in the fuse block. just my 2cents
How do you hook up stuff to the fuse box?
If you think you might be adding other electrical accessories, you could do what I did - add a fused wire to each of the BATT, IGN, and ACCY terminals and run them to a convenient location behind the dash so that you'll have easy access for future installations.
There is no need to add any fuses to the fuse panel to activate the terminals - they are already live. They are terminals designed specifically for aftermarket accessory installation (they're not just openings with missing fuses). However, they are protected only by large capacity fuses and fusible links so you should always add an appropriately sized inline fuse to any circuit you install.
Although connecting to the cigarette lighter/power outlet wires will work, it will provide constant battery power so you will have to remember to turn off your detector when leaving the car. An ignition or accessory controlled circuit will turn on and off with the ignition so you don't have to worry about it.
BTW, you would want to hook it up in parallel (not series). Series would mean that you connect the ground (output) from one device to the power (input) of the next. Parallel is when you connect both devices to a common power source.
