amp
Old Jul 31, 2005 | 02:36 AM
volcanic2345's Avatar
Question amp
iam about to get an audiobahn amp and want to install it myself , what do i need to buy and do thanks
Old Jul 31, 2005 | 07:21 AM
methane's Avatar
power wire, ground wire, remote turn on wire, inline fuse, and rca cables, do you know which audiobahn amp it is?
Old Jul 31, 2005 | 09:36 AM
2MuchRiceMakesMeSick's Avatar
You should look into buying an amp kit depending on the size amp you have.
Old Aug 1, 2005 | 01:27 AM
it is an 1600 watt amp ,model-a8002t
Old Aug 1, 2005 | 01:31 AM
pics-
Old Aug 2, 2005 | 02:12 AM
Shackelford's Avatar
Yep get a kit for your size amp w/ all that in there
Old Aug 2, 2005 | 02:26 AM
I wouldnt expect 1600 watts out of it being as it only has 2-30 amp fuses. You should be alright with an 8ga amp kit. The amp also accepts 8ga for +12 and - so that will be your best bet.
Old Aug 2, 2005 | 02:32 AM
I wouldnt expect 1600w out of that amp being as it only has 2-30 amp fuses. An 8ga amp kit should be just what you need. The terminals accept up to 8ga on the +/- 12v side so that should be your best bet.
Old Aug 2, 2005 | 02:51 AM
thanks i got it hooked up today
