mounting pics of satellite recievers
Originally Posted by Slammed99s10
It's a metal bracket made by Pro Fit.
My Sirius unit has a 1/8" output, thought about doing what you did and using an adapter for the cd changer port but wanted to give the relay module a try first. It's actually a 1000% better quality than the built in fm modulater, but not as high quality if I had xm/sirius headunit & add-on unit that uses a s-video type connecter.
It's actually the standard mount, but not specifically designed for the fbodies. Before I sold my bagged 99' S-10 I took all the stereo stuff out, including the sirius unit. So the Pro Fit bracket is for a 94-04 S-10, but I had to bend it sligtly to fit the camaro dash piece. Here are a couple more pics of how it's mounted:
![](http://memimage.cardomain.net/member_images/2/web/1178000-1178999/1178174_33_full.jpg)
![](http://memimage.cardomain.net/member_images/2/web/1178000-1178999/1178174_34_full.jpg)
![](http://memimage.cardomain.net/member_images/2/web/1178000-1178999/1178174_35_full.jpg)
It looks so so from the passenger side, but it works perfectly and that's really all I'm worried about till I upgrade to the add-on unit later on.
Originally Posted by co.6z28
thanks. is it the standard mount or the swivel type
okay..i'ma lil lost. I jsut got the idea that i want my sirrus player to play through the mooson head unit. what would i need to do this? I'm thinking about taking a trip over to radio shack or walmart and picking up what I need to do this. is it worth it? My service cuts out a lot cause I have my atena mounted on the dash right now. can anyone post some links of what I would need and how to do it? thanks.
Ungrounded Moderator
Originally Posted by WhiteBird00
OK, if you want to have a direct connection from your satellite radio to the HU (i.e. not using an FM modulator) then you will have to have a car with a cassette HU or one that is newer than mid-1999 if you have the single-CD head unit. Then you will have to buy an auxiliary input adapter such as the PIE GM9-AUX to convert the CD changer port on the back of your HU for use with an auxiliary source. Finally, you will need a patch cable to connect from the audio out jack on the satellite radio (headphone plug) to the auxiliary adapter (RCA plugs).
http://www.bestbuy.com/site/olspage....=1089890841850
this is the tuner that I have with the car kit.
Copy & Paste Moderator
#32
Originally Posted by VIP1
Check out this thread:
https://ls1tech.com/forums/showthread.php?t=359085
#33
is this it?
http://cgi.ebay.com/ebaymotors/GM9-A...ayphotohosting
I can't find it on radioshack.com, walmart.com, circuitcity.com, or bestbuy.com
#35
is this it?
You wont find it at RadioShack.
CircuitCity or BestBuy might have it in their car audio bay.
(not on their websites).
Or, you could buy it where I bought mine: www.myradiostore.com
Specifically:
http://www.myradiostore.us/auxadapte...r/gm9-aux.html
(The pic is wrong, but its the right item.)
($70 + shipping)
#37
The stock antenna can't be used for satellite radio reception - it's not tuned to the necessary frequency (not to mention it has the wrong impedance and connector).
Which radio do you want to get rid of the antenna for? You need an antenna to receive satellite radio but you can remove the stock AM/FM antenna and fill the hole just like any shaving job (door handles, etc.).
#38
#39
I want to get rid of the sirrus atenna because i can't really mount it on the outside of the car because most of the car isn't metal. I thought there was a way to hook it up so you didn't hav eto use they're crappy atenna?
![](http://memimage.cardomain.net/member_images/2/web/1178000-1178999/1178174_36_full.jpg)
#40
You cannot get rid of the antenna - without it you will get no reception at all. However, as Slammed99s10 said, you don't need a metal surface to mount the antenna. You can stick it on the roof with two-sided tape (although I would hate to use that stuff on a painted surface). You can mount it on the trim bar between the t-tops (plastic) and run the wire under the back edge of the bar. Or, you can read the various threads posted by VIP1 earlier in this thread to see other solutions for mounting the antenna such as inside the spoiler.
