speakers by back passengers dont work!
Old Aug 9, 2005 | 01:05 PM
rjkZ28's Avatar
Default speakers by back passengers dont work!
hey guys i recently installed my alpine head unit in my camaro and i noticed that the 2 middle speakers (the ones by the back seats) dont work. they worked when i had the stock head unit in there, also it is a monsoon system i dont know if that helps. but if someone can help me out that would be great. thanks!
Old Aug 9, 2005 | 03:47 PM
rjkZ28's Avatar
does anyone have any idea why they wouldnt be working?
Old Aug 9, 2005 | 06:02 PM
stange567's Avatar
hahahha rich no one replied to you.. and i know the answer!!!
Old Aug 9, 2005 | 11:17 PM
sercastiK's Avatar
thats because monsoon is a giant ************ to deal with.
Old Aug 9, 2005 | 11:34 PM
98SuperSport's Avatar
on my 94 lt1 z28 the two speakers by the passengers in the back don't get powered, and i tested them to make sure they work, have no clue what is wrong
Old Aug 10, 2005 | 07:09 AM
WhiteBird00's Avatar
Ungrounded Moderator
When you installed the aftermarket head unit did you do anything else? The sail panel speakers are powered by the Monsoon amp not the head unit. If you disconnected the Monsoon amp then there would be nothing going to those speakers.
Old Aug 10, 2005 | 08:21 PM
Silver98camss's Avatar
You would need to get a small amp to power those two speakers. The stock deck had an amp connected to it which the new deck doesn't have access to. My suggestion is get a 4 channel amp, wire the doors and the sides into it and let the rear two get powered by the deck...JMO
Old Aug 11, 2005 | 12:32 AM
rjkZ28's Avatar
hey i appreicate all the feed back. i think i am gonna go with just getting amp for the fronts. thanks again everyone.
Old Aug 11, 2005 | 07:10 AM
Well, not exactly. If you wire an aftermarket head unit into the same connections as the stock Monsoon head unit (using a wiring kit) then it will have the same outputs as stock and everything will work. The Monsoon amp takes speaker-level input from the head unit so any HU will work as long as it's wired correctly and you don't disconnect the factory amp.
If you decide to put in a different amp then you should replace the 2-ohm factory speakers as well (because of the odd impedance and because they can't handle much power).
Old Aug 11, 2005 | 04:51 PM
d36693's Avatar
take the stock monsoon amp out, the one located on the pasenger side under the rear sub speaker. Conect the wires that go together and it works great. had to do it to mine.
