cluster bulbs
Old Sep 15, 2005 | 06:08 PM
ls2 bait's Avatar
Default cluster bulbs
does anyone knowif the 194 bulbs will work in our clusters-i know it calls for 161's but they look the same next to each other and i cant find led ones in the 161 at the local parts store. whats the diff anyways?
Old Sep 15, 2005 | 06:22 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Why not just go with Nates LED's for the guage cluster? ( LS1_SS )
Old Sep 15, 2005 | 09:58 PM
ls2 bait's Avatar
i was looking to see if i had any local options that werent 35 bux so if i didnt like them i wasnt out 35 bux. bought headlights off the internet that i didnt like so it cost me 40 bux more to do my headlights.
Old Sep 15, 2005 | 10:27 PM
Lithium's Avatar
I am sure that Nate would give you a refund if you didnt like them. Hes a real cool guy, he has helped me out a lot.
Anyway good luck to you...TTT.
Old Sep 15, 2005 | 10:38 PM
95stroked1500's Avatar
if i'm thinking of my #'s right, they're basicly the same. they also offer incandescents with colored coatings. that way you can still dim your lights. led's are primarily on/off, not much for dimming.
i spent about $100 to do mine with led's. probably going to redo it in the colored incandescents. it cost so much because i got the 5 tip led's.....notice i don't have any hot spots.
click pic to make it larger.....
Old Sep 15, 2005 | 10:53 PM
ls2 bait's Avatar
i didnt know u couldnt dim the led ones but now that u say that it makes sense.....i dont like that. i thinkill try and get some colored incadesents. id actually just like to get a ta cluster beings i like the font better anyways. the one thing i dont like about the reg bulbs is it seems as though they would be dimmer beings its the same light but with a colored tint on it. mine are too dark as is.
Old Sep 15, 2005 | 11:31 PM
is there possibly a problem with the rheostat (i know what i'm trying to say, i just hope i used the right term) in your dimmer control? i'd check that out, if you're getting proper voltage through it, then get just 1 colored incandescent for a test run.
Old Sep 16, 2005 | 07:37 AM
WhiteBird00's Avatar
Ungrounded Moderator
As you've seen, the 161 and 194 bulbs are identical in shape and are physically interchangeable. The difference is in the wattage and corresponding brightness. The 161 produces 1 candlepower whereas the 194 produces 2CP so it is twice as bright. You can replace all the 161 bulbs with 194 but you probably shouldn't mix the two in the cluster because you'll have bright spots that will look odd.
Old Sep 16, 2005 | 09:10 AM
ls2 bait's Avatar
sweet im all about brighter.
