Did anyone try to fit 8" subs by the rear seats?
Just incase someone gonna do it , the model of the Jon’s subs : PYRAMID WX85 8" CLEAR POLY WOOFER 4 OHM and the dimentions are : Overall Diameter: 8", Cutout Diameter: 7", Mounting Depth: 3-5/8", Magnet Diameter: 4-1/4", Magnet Height: 1-1/4".
So we know those would fit without a problem.
Ok, Im gonna do it. Im gonna do some sub shopping tomorrow. What you guys think about RockFord P28S4?
or
Those are available in our village and I would like to Punch them in. I would like them better if the name would be like RockPontiac or GMRocksfosgate
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Josh_101
Hey speaking of those JL audio's I posted, since they are rated at only 3ohm, can an amp that can run speakers at 2ohm power that sub just fine and still get loud?
Is it pissible to get in the area behind the speaker to make an incloser?
Honestly I don't know if you could. If you were to do it you would probably have to do alot of measuring and fabrication. Then you would have to put it toghther peice by peice inside the speaker area. But if you really wanted to tear into it and have the tools im sure you could make plenty of room by cutting away and put a custom box in and then put everything you cut back were it belongs. Either way i don't think it would be easy.
Originally Posted by JonB
You would definatly have to do some cutting to get that speaker to fit. There is a support piece behind the speaker that is kinda of to the side. I'm sure you could more/ cut it some. I would like to see someone do a bad *** 8in setup with a small box built in there that would be badass.
I also used a deflex pad behind the subs. Heres a link to them
For the whole setup i only spent about $100 and it made a huge difference. I you go with a quality speaker and amp im sure it will take it to a whole other level. Hope this helps you guys out.
Also like i've heard before, did you just eliminate the very back 2 speakers? As I hear they are useless.
btw, great idea and sweet setup.
Originally Posted by 00slpSS
I've never used a deflex pad behind subs, does it go over the back cone part of it, or just rest behind the speaker on whatever surface is behind it?
No i did not eliminate the rear speakers. They are not totally useless and i would not get rid of them. They help with the overall sound with out them the only sound besides bass that i would have would only come from the front and would not sound all that great. It would be like turning your fade on the radio all the way to the front.
#33
I used my old Pioneer stereo amp w/build in crossover, 2 Rockford FosgateP28S4 subs.
The sound is awesome. I couldn’t say that is just improvement over stock - this is a GOOD UPGRADE!!
I was impressed, didn’t even thought that its gonna be that good!
#38
Hmmm, I need to see how that works, I was wondering where the screw holes were. Just looking at it, man you'd be thinking, "damn that thing's a beast!"
Heres a perfect way of how show to people, It'll prolly be loud as hell for a 8" sub, people ask you, "woe! you gotta system in here?!? Let me see! Open up the trunk hatch, they'll see nothing, and say "WTF??, ok whats going on?!". Then show them the 8" subs, and they'll **** there pants, lot literally but...they'll be shocked!!
Just gotta supprize people man!
