Daytime running lights
Old Sep 29, 2005 | 10:10 PM
CONVERTED's Avatar
Default Daytime running lights
I want them..
I have a 95 t/a i converted (hense my name) to an 02.. Everything in and out is 02. i lub the way these cars look with the amber lights on. but i hate when i forget about them and leave my battery drained.............. Own3d.....
So what would be the easiest way to hook them up so they turn on and off with the car?
Figured you guys know your wires...
help a noob out...
PS i'm sure to be lurking around here more often. you guys have some freakin kewl stuff in the trunk.
Old Sep 29, 2005 | 11:28 PM
komik's Avatar
Some companies make modules for adding DRL's to your vehicle.
Here's one example:http://www.autotoys.com/x/catalog/Re...ghts_p_29.html
If you have some electrical knowledge, you can do it yourself cheaper with a few parts from RadioShack (wire, resistors, relays, etc.). It shouldn't be too difficult.
Old Sep 29, 2005 | 11:35 PM
CONVERTED's Avatar
Thank you much.
Old Sep 29, 2005 | 11:53 PM
komik's Avatar
If you want to try DIY...
12VDC/30A Automotive Relay - $6.29
http://www.radioshack.com/product.as...5Fid=275%2D226
Here's a quick schematic I drew up. It could be wrong, so you may want to wait for a second opinion if you decide to go this route.
I'm not sure which poles would be which on the relay, but it's probably clearly labeled. The light socket has three different color wires coming out of it, but I'm not sure which is which. I think they are blue, brown, and black (I just swapped one out the other day, but can't remember for sure). Black we would assume is ground. If you can't find a diagram showing what the other two are, just tap a +12V lead into each one and see how bright it lights up.
Old Sep 30, 2005 | 12:59 AM
FastPacedGTO's Avatar
remember it's gotta shut off when you hit the turn sigs.
Old Sep 30, 2005 | 07:50 AM
WhiteBird00's Avatar
Ungrounded Moderator
Interesting project. The DRLs are different from just turning on the parking lights - DRLs run the bright filament in the bulb rather than the dimmer parking light filament and DRLs run only on the front whereas parking lights also turn on the tail lights.
You want the DRLs on when the ignition is on but the headlights are off (they switch to parking lights when the headlights are on) and you need them to still flash when you use the turn signals.
The factory DRL module is solid state but I think you can do this with just a couple of relays on each side. I'm going to have to sit down with some paper and work out the connections. If you really want to do this, let me know and I'll see what I can come up with.
Old Sep 30, 2005 | 10:59 AM
komik's Avatar
So I forgot a few things... It was tired. Anyway, maybe buying a module would be the way to go.
Old Sep 30, 2005 | 10:24 PM
ZeeVert's Avatar
I couldn't resist trying...
Circuit #1 will light the Turn light on. The turn signal pulse will actually turn it off. (Resistance of the Relay would have to match the bulb... but how?)
Circuit #2 adds a relay to disconnect the ignition signal when the parking light is on and make the turn signal pulse work normal.
Think it would work?
Old Oct 1, 2005 | 05:44 PM
CONVERTED's Avatar
I'm very interested if I can get an agreement on the proceedure i'm down getting it done.
Old Oct 1, 2005 | 06:00 PM
komik's Avatar
I disagree with my diagram and agree with Zee Vert's. His is prettier.
Old Oct 1, 2005 | 07:51 PM
ZeeVert's Avatar
...and prettier is better?
The only problem with mine is the resistance value for the coil in the relay. The turn signal system may not like it if it doesn't match the bulb. and I suck at resistance calcs.
The good news is that it only costs a couple relays to try it. And relays can be used for other things if it doesn't work.
Old Oct 2, 2005 | 02:57 PM
Forget about circuit #1 unless you want high intensity parking lights when your headlights are on. Circuit #2 looks like it will work pretty much like the factory setup.
You can overcome the resistance problem by just replacing the stock thermal turn signal flasher with an electronic one (about $7). This will maintain a constant flashing rate regardless of the extra resistance of the relay coil.
One oddity about circuit #2 is that the front signals will flash opposite the rear (i.e. the front lights will go off when the rears go on and vice versa). Not a problem - just
an interesting side effect.
