Speaker Help please
Old Oct 17, 2005 | 09:56 PM
killer01ws6's Avatar
Default Speaker Help please
Ok 2 weeks ago my drivers side sail panel speaker blew while the wife was driving Red... (bad wife )
I asked around for replacements and a guys said he had some,
I get them and tonight I get ready to put them in.
This is where the "However ," comes in.
The ones he sent me are a single voice coil with 2 wires in the connector and are 2 ohms.
I pull mine out and it is a dual voice coil with 4 wires in the connector, and it is 4 ohms.
both of them were GM paper type speakers.
Now, did I get the wrong ones sent to me, or has mine been changed.. OR are they different due to year?
Heck if I knew they were 4 ohm, I would have just went after market, the reason I wanted stock was the 2 ohm system.
ANY info that can clear this up would be appreciated,
Pete
Old Oct 17, 2005 | 10:28 PM
well after some research (should have done more up front I guess) My speaker I need is a 9365799
which is a dual voice coil 4 ohm speaker, I am just not sure where the ones he sent me go...
Old Oct 18, 2005 | 02:30 AM
HiTechGent's Avatar
Probably in the sail panels of a Camaro. Not sure why GM used different speakers than what's in the Firebird.
Old Oct 18, 2005 | 05:39 AM
That is odd, I can see a difference in the verts and hard/T-tops.... but not any others.
The part number off of it did not cross to any info I could find, but the number is 10447249
Old Oct 20, 2005 | 05:23 PM
HiTechGent's Avatar
When I replace my sail speakers (next month, likely), I'll let you know if they match that part number.
Old Oct 20, 2005 | 08:59 PM
DevonsZ's Avatar
10447249 is the same # on my sail panel speakers that I just took out. So GM used different speakers for the cars or yours were already replaced?
Old Oct 20, 2005 | 09:43 PM
Duffster's Avatar
My two cents -- -- -- If he sent you a 2ohm speaker single coil, sounds like a monsoon speaker. If you were running a 4 ohm speaker with two coils, sounds like a non-monsoon speaker. . . If I still had my monsoons I would check the numbers for you. Sorry.
Duff
Old Oct 20, 2005 | 11:22 PM
HiTechGent's Avatar
The stock Monsoon speaker in the T/A sail panels had dual voice coils. One 2 ohm, the other 4 ohm (weird, I know). The Camaro stock Monsoon speaker had a single 2 ohm voice coil.
Killer wanted the T/A speaker and bought the Camaro speaker by mistake.
Old Oct 21, 2005 | 09:12 AM
This appears to be what happend, twice!
