biggest amplifier to electrical system?
Thanks
for that alpine m1005 amp it says 4 gauge. Is that big enough? I was also planning somtime to put a small 4 channel for speakers and use a distribution block. Will 4 gauge to the block be enough for the sub amp and small 4 channel. 50 X 4 amp?
Thanks
p=iv
1000 watts = i * 12.6V
i=79.37 amps.
then you take this number and factor in efficiency of the amplifier. most class D amps are 70-80% efficient. so....
79.37 amps*1.20=95.24 amps
so the amplifier alone would draw around 95 amps. factor in another 45ish for the factory accessories like lights etc, you're looking at 140 amps right there. if you have additional amplifiers or any aftermarket parts that draw more current, you're most likely going over the output in amperage that your alternator can do.
with that said, these are the calculated numbers assuming your amp will be at full tilt, full amperage draw at all times. to know whether or not you will be fine depends on your listening habits, but i'd be willing to be you should be a-ok.
to give a blanket statement like "4 gauge will be fine for this amplifier" is technically incorrect because it depends on the length of your run. if the distance that you're going to be running the cable is around 12-13 feet or more, you might want to consider bumping up to 2 gauge. but i highly doubt that to be the case, so the 4 should be fine for this situation.
