interior power question
Old Dec 26, 2005 | 09:55 PM
slimcracka's Avatar
Default interior power question
ok i recently got a xm radio roady2 and an radar dector for x-mas.
and they both came with cigrette lighter power hook ups... and i dont want just wires and plugs layin around every where (im a neet freak) and was wondering if it would be ok to hard wire the radar dector in to my car(with an inline fuse of course) i dono if ill be able to do it with the xm radio or not because the conector converts it from 12v to 6v as well..so ill figure out something
sorry its so long
thanx
justin
Old Dec 26, 2005 | 10:00 PM
slimcracka's Avatar
and when i hard wire it in where should i do this from? thanx again.
Old Dec 26, 2005 | 10:24 PM
Trev_SS's Avatar
https://ls1tech.com/forums/wiring-stereo-electronics/427205-place-get-power-my-xm-radio.html
post 4 helped me out a bit and then all the rest was easy on from there hope this helps
Old Dec 27, 2005 | 11:59 AM
todddchi's Avatar
Both of those things should be of low enough power draw to tap off the head unit wiring.
I'm not sure about the XM wiring but the radar detector for sure will work - ground and switched 12V - so it comes on automatically with the car power.
Old Dec 27, 2005 | 12:04 PM
2K2WS6TA's Avatar
You could also use the RAP wire that goes to the radio to power the lighter plug I mentioned, that way you can still have the XM (until the radio goes of or you open the door) then use the TCS power wire for the radar detector I wouldn't reccomend putting both on the same wire (might start blowing fuses, might not )
Old Dec 29, 2005 | 07:24 PM
slimcracka's Avatar
thanx guys anything else would help
Old Dec 29, 2005 | 07:28 PM
slimcracka's Avatar
so the pink wire in the tcs + ground would be 6v?
Old Dec 29, 2005 | 07:44 PM
2K2WS6TA's Avatar
No it's 12v, power the extra lighter socket with it, and plug the XM lighter plug into that
DO NOT UNDER ANY CIRCUMSTANCES PUT 12V TO YOUR ROADY, YOU WILL FRY IT
Old Dec 31, 2005 | 12:37 PM
slimcracka's Avatar
i got a volt meter so ill check everything..even with it powered up to make sure im getttin the right volts...and i know its 6v..im got a female lighter socket with two wires comin out if it im goin to attach in the dash and just have it hooked up like its supose to be but hidden in the dash..so i dont have wires hangin every where..im a neat freak!
