Will these work? Alpine Type-S SPS171A
Will this component set work for the front door? I currently want to use the factory amp, sail panel speakers, and rear speakers. I have an Alpine CDA-9833 head unit. I blew one of the door speakers and want it fixed pretty soon. I was originally going to do a whole system upgrade, but ran into financial issues. And yes, I've read and read the sticky and many different search results. It seems that no matter the subject, some say one thing and somebody else says another.
I am basically wanting to know if this setup would plug and play or not? If not, what would I need to do for it to work or is there a better quick fix?
and they are partially correct, those speakers need more than the 20 watts (or so) rms from the deck, but it is still in the power range
If you hook them up directly to the head unit, It should sound just fine. The midbass freq's just won't be as loud at the same volume setting as it would running thru the amp. And if the rear channel is still amped, you'll have to adjust the fader forward to compensate.
Alpines straight from the head unit or from the amp with the crossover
Either one would work then? Once I get the door panels off, it'd be easy enough to try both ways and see what sounds better. As long as they'll work, then I'll probably go ahead and place an order for them this weekend.
I understand the theory of crossovers (I work in electronics/engineering with radio frequencies), but I haven't actually had to hook them up before.
Get rid of the monsoon amp. Find a wiring diagram for the fat 32 connector harness, and just jumper the appropriate wires so they loop thru the harness. The factory wiring is quite sufficient to handle the power output of a HU.
Here's a quick question to add to the list...
I keep reading about the infinity 2 ohm speakers. Most of the people talking about it are the camaro owners though. On my bird, would they be better for the front replacements or not?
