Daytime running lamp bypass
The reason it doesn't work on manuals is because the power trunk will no longer work as the brake light will not illuminate on the dash when you pull the parking brake.
The blue connector on the DRL module has eight cavities, but only seven of them are used. Cavity B is empty. I discovered that if that terminal is grounded, your DRLs are disabled. The black wire in cavity A is a ground, so I took the DRL module apart (easy to do, the cover just slips off) and solder-jumpered the A and B terminals on the PCB. This leaves you with no DRLs, you power hatch and handbrake light still works, and it all looks factory. Easy to undo if you want.
Some people have expressed a desire for a switch to select whether you want the DRLs or not. This is very easy to do. All you need to do is put a switch inline with the wire that's jumping cavity A and cavity B, and that's it. You will not need to be concerned with fuses in this situation because you're jumping a ground, not a hot wire.
Id like to know the same. I really dont understand the people that disable airbags to put in a screen.
But, I agree with whatbrown 100% as I don't like the way cars look with DRL's either. On top of that, the bulbs will last longer once the DRL's are disabled. Lastly, I don't recall seeing any Fords with DRL's. So until they become a requirement on all cars, mine are staying off. They're disabled on my dad's 99 vette as well.
Or you can do like me, have your DRL's burn out, then you dont have them....
