Best non-alarm theft deterrent?
#42
A cheap and easy solution is just a master power switch. Lots of racers are required to have external battery switches. It would be kind of like that, but internal and hidden. I am installing one of these on my wifes car, because she has an electrical problem that neither me, 2 dealers, or a company full of electrical experts can figure out so... I'll just cut main power every night. No battery, means no drain. Later on, I realized this is a great theft deterent too. Sure all they have to do is find the switch, but what if they can't? It's even better if the switch is hard to recognize. I like the cigarette lighter idea someone mentioned.
#43
Ok...Ive found MY answer
I bought a Cyclops Immobilizer...its the best thing since sliced bread.
It uses a relay which replaces EITHER your fuel pump relay OR your starter relay...
Installation is
1. Pull Old relay
2. Plug in new relay
3. Done
You press your key fob button ( which is the size of a 50 cents piece and about 1/4 thick)..like thsi but round
to start your car, you have a 30 sec window to do so after which you need to press it again
Im keeping the real relay in the rear compartment of my car just in case of key fob battery failure etc ...and Ive found a hiding place for the fob.
So now If someone trys to jack my car....I can just turn it off or hand them the keys get out and walk away...Car no start!
Installation is
1. Pull Old relay
3. Done
![](http://www.dynamco.com.au/store/images/REM-004-C.jpg)
#44
Installation is
1. Pull Old relay
3. Done
Installation is
1. Pull Old relay
3. Done
Another cool thing is that you can take the fob apart and run the contacts to any switch you want. Seat switch, hidden switch under the brake pedal activated by toe, whatever. Even a pressure switch under the upholstery that is not seen. Those in the know just press that area and bam, she starts. They are cool devices. Didn't we already talk about them earlier? I can't remember.
#46
I've heard a lot of good things about the Autolock but have never bought one. I kept trying to convince my mom to buy one for her car so I could test it out....
JasonWW... how many people have commented on how hot your damn sig is? God damn.
#47
Are they the same?
Here is the inside of one, BTW. Lot of circuitry going on in there.
![](http://img.photobucket.com/albums/v335/JasonWW/Misc%206/IMG_2035b.jpg)
![](http://img.photobucket.com/albums/v335/JasonWW/Misc%206/IMG_2034b.jpg)
I think these devices are kick ***. We all need hood locks of some kind to really help, though.
#49
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Originally Posted by HiTechGent
How about the 70's approach. Install an 8track player, **** carpet on the dash, and tie-dyed seat covers (with peace signs). And don't forget about the fuzzy dice hanging from the mirror. lol
![Icondrool](https://ls1tech.com/forums/images/smilies2/icondrool.gif)
#50
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#51
So I put a relay inline on the cigarette lighter ground wire. When I press in the cigarette lighter it trips the relay. But, the cigarette lighter doesnt work anymore. Why doesnt it work anymore and how do I get it to work?
Im using a 30amp automotive relay.
#52
You might try hooking the relay up with it tapped onto the ground wire. Reconnect the cig ground like it should be, then tap one side of the relay trigger to the ground wire and the other side trigger to ground (85 and 86). When you push in the cig lighter, it will work normally and it will supply pos. current to the relay. That should do it, but I can't say for sure as I've never tried it.
#53
Originally Posted by JasonWW
Most vehicles have a non-essential relay that is the same. Maybe a fog light, horn or something. I haven't checked the f-bodies. Hopefully we do not. That way it's harder for the crook.
It's new, just trying it out.
Autolocks are great.but their not going to stop someone from jacking your car while your in it...
Scenario..your driving down the road, come to a stop iand some person says get out...you cant say waita miniute..gotta put on my autolock..
Or if you pull your Ralveco hes going to see it gone or you doin it...
with the cyclops..I turn the car off or hand the keys to them and run....with the fob in my pocket..the cars not going anywhere.
Autolocks are great when your parking the car ..but I wanted somthing a bit more flexable
#55
Ungrounded Moderator
Do you understand how both circuits work? If the relay is open then the cig will not work. Simple as that.
#56
Yep..look jutst like that....
What would be great would be a fob or RFID tag that just needed to be in the area (in your pocket) rather than have to push a button. If you used it for the fuel pump relay, it would have to be on all the time for the car to continue to run. That way you could get out of the car and run away - the car would shut down after you got out of range of the relay's receiver.
#58
![](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/81608-best-non-alarm-theft-deterrent-cig-relay-diagram.jpg)
#59
^^I cant help you, but on another note, is there any way to prevent someone with like a flatbed from towing a car? I saw a sticker on a new mercedes that said not to tow it, but I don't know if that's anything or not.
#60
Originally Posted by jimmy 2 Times
how is an aftermarket alarm going to "really annoying in terms of liveability."
i dont get it?
i dont get it?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
1997 Trans Am A4
Specs:
Full Borla Exhuast
Ram Air Box
Air-foil
![](http://i33.photobucket.com/albums/d84/losaltos6/Sig2.jpg)
