Horn and Reverse Lights not Working
Are the horn and reverse lights even on the same set of wiring or are these two different issues I must deal with?
Also, my reverse lock out isn't working, could this all be linked together???
The backup lights could either be a fuse or a problem with the switch. The fuse is the TURN/BU fuse in the dash fuse panel. Never trust that a fuse is good because it looks good - always use a tester or try another fuse. I expect that the problem is with the switch though, because of your reverse lockout issue. The switch is in the middle of the transmission on the right side. It has two wires - brown and light green. Try shorting the two wires together with the ignition on to see if that makes the backup lights work. If so then the switch is the problem.
The backup light switch on an M6 is a simple on/off two-wire switch in the side of the transmission that allows current to flow from the TURN/BU fuse to the backup lights when the transmission is in reverse. On an automatic this function is controlled by the neutral position switch which is connected to the shift lever.
