Need Keyless Wiring Diagram!
Anyone?
For those of you who dont know...progressive door locks is when you hit the unlock button on the remote once to unlock the driver's door and then hit it again to unlock the passenger's door. These instructions show how to bypass it so that both doors unlock on the first press. The second press of the button will then be an extra channel giving you the ability to control other options such as remote start, window roll down, turn on radio, whatever you can think of that needs a pulse to activate.
1. Look under the glove box. You will see a black panel that covers everything above it. There are two clips right at the base of the glovebox that hold the front side of the panel up. Remove these clips so that the panel hangs down giving you access to the wires above it.
2. Look for a green plug. There will be five wires in it: orange/black stripe, red/black stripe, gray/black stripe, tan, and gray.
3. Unplug the harness. The female side is the bigger side and is light green. The male side is the smaller side and is dark green. You will be working with the female side.
4. Cut the gray/black stripe wire on the female side.
5. You should now have a short length of wire going back into the female plug and the other side goes back into the wiring of the car. Splice the side going back into the plug with the tan wire.
6. The wire that goes back into your car is now your extra channel on your alarm. It is a 12V pulse.
Some cars just have a green plug going directly into the BCM. The wires are the same colors. Cut the gray/black wire and splice the end that goes into the car to the tan wire. The short portion of gray/black wire that goes into the BCM is your second channel.
Most remote starts and window modules need just a pulse to activate. This will give it to you now from the factory keyless entry. Installation of these components would be done just as if there were an aftermarket alarm except that you would hook the trigger wire to the grey/black wire that is left over.
The second channel will pulse when you press the unlock button on the key fob twice. This is handy for accessory use. It will also pulse if you press the unlock button on either door. This is not so handy for accessory use. There are various ways you can avoid this (e.g. a cutout relay for when the ignition is on) but it is something you should be aware of when connecting an accessory.
the cut black/grey wire GOING TO THE CAR should splice into the tan wire. the extra channel is the left over wire GOING TO THE PLUG
also this 'green plug' is just one plug that connects to a big black module in the most uppper right section under the panel. it is not a separate male/female plug pair.
