speaker whine
Old Feb 22, 2006 | 08:05 PM
Blown Ta's Avatar
Default speaker whine
what usually causes this with aftermarket systems?
it gets louder when driving, quieter at idle.
thanks
Old Feb 22, 2006 | 08:17 PM
kornfreak_401's Avatar
wires are crossed or something. this usually happens when the install is done below avereage, in other words, a shitie job (no offense if you did it, everyone makes mistakes) when people do it half *** or take shortcuts...
Old Feb 22, 2006 | 08:27 PM
Blown Ta's Avatar
yup, it was installed by me, what wires could be crossed? speaker wires?
everything else works perfect. sounds great, which is good, spent a lot
of money on this system. no short cuts were taken, as this is my car.
Old Feb 22, 2006 | 09:26 PM
Xtremespeed's Avatar
If the wine increases with engine rpm, you have a ground loop problem. You need to check all your grounds and make sure you have good connections to the chassis. It's best to check your ground with a meter and make sure you have almost no resistance. Are you using an amp? Amp grounding problems are where this problem usually surfaces. Also make sure you don't have rca cables or speaker wires run next to power cables. Hope this helps.
Old Feb 22, 2006 | 09:34 PM
Blown Ta's Avatar
i am using a zapco 360 to power a/d/r spaeakers.
and yes my spaeker wires and rca's are ran right nex to
my 1 ga power cable for the battery that a relocated in the trunk.
will it help if i some how cover the wires or should i just rerout them?
i will check the ground as well.
thanks for the help
Old Feb 23, 2006 | 12:27 AM
2MuchRiceMakesMeSick's Avatar
Usually when the patch cord comes close to a 12v wire.
Make sure that you have the preamp and the 12v seperate.
I run the 12v on one side and the preamp on the other.
Old Feb 23, 2006 | 10:34 AM
HiTechGent's Avatar
Seperate the RCA/Speaker wires from the power wires. Amplifiers require considerable current. THe higher the current, the stronger the magnetic field surounding the power wires. The stronger the magnetic field, the more likely you are going to couple noise onto nearby wiring.
Old Feb 23, 2006 | 11:00 AM
TA guy's Avatar
much simpler solution as you already have the wire installed... go buy a ground loop isolator (they are fairly cheap), or borrow one, and plug it in between your RCAs and amp, your noise will most likely go away.
Old Feb 23, 2006 | 01:11 PM
Might be worth trying, but in my experience, ground loop isolators rarely work. I would say, save your money, move a few wires and check your grounds. Jmo.
Old Feb 23, 2006 | 01:23 PM
TA guy's Avatar
I have had great success with them, maby I'm just lucky
Old Feb 23, 2006 | 01:29 PM
marcus769's Avatar
I've had this problem before too... This was when i was still learning all the tricks/proper stereo installations...
Run your Power wire on one side of the car, and the speaker, RCA, & Preamp, on the other.. NEVER together, or you'll be looking at a problem like this... Its easy to switch it.. I wouldnt **** with buying anything new.. This will fix the problem.. Also.. Make sure your grounds are free of paint/rust. (make a good, solid, tight connection!)
Old Mar 1, 2006 | 05:42 PM
Blown Ta's Avatar
i got the pac rca filters, put them in.
problem solved, no more whine
so that worked out good.
thanks for the help guys.
