raptor shift light?
Old Feb 23, 2006 | 06:34 AM
mushroom281's Avatar
Default raptor shift light?
which wire do i tap on my ecm
now i have it on the same wire as my rpm module but it does not work
Old Feb 23, 2006 | 08:04 AM
SS 1LE's Avatar
depends, what car is this for and what year?
Old Feb 23, 2006 | 10:05 AM
sorry 01 camaro z28
Old Feb 23, 2006 | 01:11 PM
SS 1LE's Avatar
You can use the white wire going into the #10 pin on the lower harness plugging into the ecm. Pull the cover off of the lower connector, you will be able to see the numbers. Just splice into that wire and run the wire through the firewall using the hole already there behind the computer. It will have a grommet with some wires already running through it, so you can just make a small slit into the grommet and run the wire through the hole and under your dash. Hope this helps out.
Old Feb 23, 2006 | 01:19 PM
well hmm i already have it on that wire maybe the shift light is set wrong
thanks
Old Feb 23, 2006 | 01:24 PM
SS 1LE's Avatar
make sure you have the rpm activated module set to 4cyl. If it is on 8, it will not work properly.
Old Feb 23, 2006 | 01:28 PM
ok that is probably it i have it on v-8
Old Feb 23, 2006 | 01:35 PM
SS 1LE's Avatar
If its wired in correctly, then that will be your fix. I forgot exactly why you have to put them on 4cyl.
