Ipod to sterio?
Old Feb 23, 2006 | 02:12 PM
KilerTA's Avatar
Default Ipod to sterio?
I have a Ipod and i want to get it to run off the raido i know of one way and that is to get a itrip and just run off of a raido frequency. But is there another way i gusee hard wireing into the stock monsoon setup?
Old Feb 23, 2006 | 03:34 PM
SS 1LE's Avatar
I'm thinking the easiest way would possible be to use an FM Modulator. You can get them wireless or the ones you can wire into your car. I would recommend the hardwired one for better sound quality. Either way it will still have to be on a certain radio station. Im guessing though that the Itrip you are talking about is the exact same thing.
Old Feb 23, 2006 | 03:46 PM
DVST8OR's Avatar
They make a PAC adapter that you could use which hardwires it to the AUX port of your headunit. It charges it while plugged in and turns it on and off with the ignition. Thats what I used.
Old Feb 23, 2006 | 05:48 PM
max5's Avatar
I have what you need for sale. if you have a cd changer, then you need the PAC AAI adapter. it gives you two rca inputs, and a switch to change between the two. I have it for sale, $50 shipped, that's cheaper than you will find it anywhere else, and if you look at other post in this forum people have said that this connection sounds even better than cds, no messing with frequencies.
Old Feb 23, 2006 | 05:52 PM
Phoenix 5.7's Avatar
beware it depends on the year. cd players before 00 can't accept an adaptor, only the tape players of those years. 00+ cd players can accept an adaptor
Old Feb 23, 2006 | 05:57 PM
KilerTA's Avatar
Can i see some Pice or some web links to what some of you are talking about?
Old Feb 23, 2006 | 10:13 PM
max5's Avatar
ya sure no problem killerta. it's brand new, I bought it for my firebird, but I didn't realize that this adapter needed the cd changer to work, so I have to get a different one. The part is actually on ebay right now, but I dont have any bids(and it's not looking good). you are wecome to bid on it, or I can stop the auction right now and sell it to ya, There are pics on the auction. Here is the link, and a few other infor links. The pictures from the other links are exactly what I have, brand new.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5869616457
http://shop.store.yahoo.com/logjam/pacaaigm9.html
http://www.pac-audio.com/products/pr...iliary%20Input (scroll down to the gm9 connector)
Old Feb 23, 2006 | 10:18 PM
SmokeySS's Avatar
Here's what I'd like to know. If you connect it to the Monsoon or a different aftermarket headunit, is there a way to change songs with the steering wheel clicker?
Old Feb 23, 2006 | 10:31 PM
max5's Avatar
Ya, but you have to order what is basically just like the gm9 aux unit(It plugs into the changer port, which runs to a small white box, that has a white ipod docking cable coming out of it). it's like $130 or somehting like that, i forget the name of it. type in "gm9 ipod" and you should come up with it in google. I was thinking of doing this, but I realized I would be using hte click wheel mroe often anyways.
Old Feb 23, 2006 | 10:42 PM
VIP1's Avatar
Copy & Paste Moderator
The PIE GM9-AUX only converts the CD-Changer port to RCA AUX-IN.
It does not use the steering wheel buttons to control the iPod.
(I have a PIE GM9-AUX)
I think what you need is called an AUX-POD....but I'm not sure.
Here is a post I made recently on this subject:
https://ls1tech.com/forums/showpost....74&postcount=2
-Note-
If you have a 98-02 Cassette Deck or a mid-99-02 CD player then it can control the stock CD-Changer and can work with the GM9-AUX. The pre-mid-99 CD headunit can't control the stock CD-Changer. If you have the 01-02 CD Headunit then it can control both the CD-Changer and the GM9-AUX (the earlier ones can control only one or the other, not both).
Old Feb 24, 2006 | 12:49 AM
1998sscamaro's Avatar
they have a tape that plugs right into the ipod and works really good, and u just use it as if u were playing a cassette.and u dont ever have to listen to that annoying static and its only 15$. heres the link ...and this is one of the more expensive ones.
http://www.walmart.com/catalog/produ...uct_id=2569421
Old Feb 24, 2006 | 06:47 AM
max5's Avatar
the tape works, but quality isnt very good at all. If you have the ability to control a cd changer I would definately recomend one of the gm9 adapters.
