What size speakers come stock in the LS1's? All 3 sizes please
Not sure if you are keeping the Monsoon amp still, if so, your limited on what type of speakers you can use. Infinty 62.7i's work perfect up front and require no modifications. I used them in the backseat too and ran the wire running to the 4inch far rear speaker to the tweeter in the sailpanel speaker to make it full range. Some people don't find out about the odd monsoon setup until they already bought the speakers and find out they don't work(dual inputs in the front and 2 ohm woofer is powered by the Monsoon amp/ 4 ohm tweeter is powered off the headunit)...Sailpanel sub is not full range and is powered off the Monsoon amp only at 2ohms...Far rear is 4ohm running off the headunit at full range.
