subs in an extended cab dakota RT???
Old Mar 3, 2006 | 01:21 AM
transambandit's Avatar
Default subs in an extended cab dakota RT???
just bought an 02 dakota RT with the extended cab, now anyone have any ideas where a sub can be mounted.
Old Mar 3, 2006 | 02:42 PM
JohnnyBs98WS6Rag's Avatar
MTX makes a Thunderform for under the rear seat of '97+ club-cab Dakotas. I have one w/ 2 10" 4000 series MTX subs in my '99 RT powered by a 450W RMS amp mounted under the passenger seat. Sounds great. The Thunderform replaces the plastic "tool tray", and can be purchased w/ a built-in amp (don't bother) or w/ just subs, or empty so you can add your own subs. Crutchfield carries them, but you can probably find them elsewhere cheaper.
Old Mar 3, 2006 | 03:53 PM
my rear bench sits almost flush with the floor though i guess they stopped putting the tool tray underneith the bench, unless there is a way to adjust the seat to make it higher, guess i will have to look.
Old Mar 5, 2006 | 12:01 AM
Junkster's Avatar
you can but 'blocks' underneath the bench to make the seat higher...at least in the GM trucks...just figure out how much higher you want to go and I've seen lots of guys use MDF and raise the seat and also depending on how high you go make the bolt longer also (and depending on how the bench is attached to the rear of the cab extend that also...
Old Mar 6, 2006 | 10:54 AM
??? Did maybe the prior owner remove the tool tray to allow the seats to pivot clear down to the floor?
Here's a link to MTX's page......
http://www.mtx.com/caraudio/products...P201_specs.pdf
The T-form does make the seat angle up slightly higher than the factory tool tray does, but it's still very usable.
Old Mar 6, 2006 | 12:27 PM
yeah i think thats what im going to get but they are kind of expensive so im probably going to get a medium density fiberboard and fashion one of my own, im going to make one for my rockford sub on one side and the amp on the other, i might even put my old xbox under the amp, see how that looks.
Old Mar 7, 2006 | 07:43 AM
2MuchRiceMakesMeSick's Avatar
JL Audio makes a nice sub box.
Bazooka makes a bass tube thats easy to install and some of them are self amplified
Old Mar 7, 2006 | 07:20 PM
wickedwarlock's Avatar
check out www.dtwtrucks.com
there's tons of info on them.
check out www.subthump.com too
