Image Dynamics or Pioneer?
For the sail panel speakers, which would you recommend, Pioneer Premier TS-M7PRS or the Image Dynamics?
Pioneer: http://www.onlinecarstereo.com/CarAu...roductID=14547
Image Dynamics: http://www.imagedynamicsusa.com/tech...midrange&id=cx
For the image dynamics do I want the 2ohm or the 4ohm?
Note: If you're worried about the 4 ohm Pioneers being not loud enough, during my install I tested my system with 1 stock and 1 Pioneer. For this test I had the hatch speakers disconnected and fader control all the way to the rear so that the only speakers heard were the sail panels. I could not detect a difference in volume adjusting the balance between full right and full left. I can tell you the the Pioneers sounded cleaner and less distorted.
BTW: There was nothing wrong with my stock sail speakers, I just wanted to upgrade, since I had already replaced all the other speakers in the car.
IMO they sound alot better
How true is this? Has anyone run the CX62s for at least a year? Also, do the IDs require any custom work or do they pretty much just drop in?
I would prefer the IDs over the Pioneers because of the impedance. Although I do like the freq of the Pioneer better. I don't blast the music either. I just want a decent and clear sound.
First, the tech guy must be assuming the stock speakers are 4 ohm. He is right that if you put the CX62's in system with an amplifier that is not rated for a 2 ohm load, you could burn up the output transistors. But since the stock speakers are rated at 2 ohm also, this seems unlikely.
In my opinion, the Pioneers are a better speaker, period. You needn't worry that they are 4 ohms. If the $185 price tag is more than you want to spend, I'd suggest looking at the Audiobahn AMD60Q's. Note: These are also 3.5" mounting depth. So you may have to shim them as FredMR did for his EU-700's.
I know this thread is old but it is still relevant to the questions that I have. Thanks for your replies by the way.
